KB-32028: Accessing local tags quickly with Remote Domains.
Question:
When using Remote Domains with a local alias, will the access to local tags become slower than the direct access?
Solution:
No, the access remains normal, because Elipse E3 detects the use of a local alias and then connects directly.
Print Friendly, PDF & Email
Leave a Reply
