KB-31996: Communication with PIC microcontroller.
Question:
How can Elipse E3 or SCADA communicate with a PIC microcontroller?
Solution:
To do so, use the ASCII driver.
However, it will be necessary to implement the protocol at PIC. It is not enough to just configure ASCII driver at E3/SCADA, for example: PIC microcontroller must also have this protocol to interpret and write in its registers. That is, both sides must “understand” the protocol to communicate successfully.
You can download this driver at Elipse’s website.
Print Friendly, PDF & Email
Leave a Reply
