Question:
The E3Storage is only recording values in the database when I use the Studio hardkey. When I run the application with the runtime hardkey, no value is recorded. All the historic objects in the application are recording values normally, with either hardkey. What could be the issue here?
Solution:
The E3Storage is an additional module, which needs to be enabled in the runtime hardkey license to work properly. In the Studio hardkey, on the other hand, it will work normally, because the E3Storage is free in this one (provided the other Studio restrictions are observed).
