Question:
I usually connect Elipse SCADA with a NetHasp hardkey via network. Now, however, I’ve connected the (parallel) hardkey in the computer editing the application, but doing causes a NetHasp error to be displayed. How can I fix this?
Solution:
At Elipse SCADA’s shortcut properties, write -setup after quotes (for example: “C:\Program Files\Elipse Software\Elipse SCADA\Elipse32.exe” -setup) and run it. On the window that will open, check Hasp in: option and select the port connected to the hardkey. Open the shortcut again, delete -setup, and run Elipse SCADA.
