KB-31777: Setting up a bit’s variation as an event.
Question:
How can I set up a bit’s change in status as an event, and not as an alarm?
Solution:
To do so, set it up normally as an alarm and then, on alarm’s Properties window, Source tab, enable the option Handle this alarm as an event.
Print Friendly, PDF & Email
Leave a Reply
