Question:
Can I access IOKit‘s options via application?
Solution:
Yes, you can. In E3 Studio, when the driver is open, you will just have to access the option Tag Browser.
Another possibility is to set the tags’ N parameters directly in IOKit. For further information on IOKit‘s use and settings, please refer to IOKit‘s manual.
Note: E3’s documentation can be found for download at our website.
