KB-31560: VBScript’s version used in E3.
Question:
Which is the VBScript’s version used on E3?
Solution:
E3 uses the version that is installed in the computer (C:\WINDOWS\system32\wscript.exe).
Via E3, you can retrieve the version of VBScript being used by using ScriptEngineMajorVersion, ScriptEngineMinorVersion, and ScriptEngineBuildVersion functions on a button’s Click() event. For example:
   Dim varaux
   varaux = “”
   varaux = ScriptEngine & ” Version “
   varaux = varaux & ScriptEngineMajorVersion & “.”
   varaux = varaux & ScriptEngineMinorVersion & “.”
   varaux = varaux & ScriptEngineBuildVersion
   MsgBox varaux
Print Friendly, PDF & Email
Leave a Reply
