KB-31508: Using Sleep function in E3.
Question:
Can Sleep function be used in E3?
Solution:
VBSscript’s Sleep method (Windows Script Host – WScript Object) cannot be applied to E3.
Furthermore, techniques that “consume” time and/or interrupt the execution of scripts cause the application to underperform and, in most cases, can be replaced by other alternatives, such as a Counter or Demo tag, for example.
Print Friendly, PDF & Email
Leave a Reply
