KB-31412: Converting the Query’s E3TimeStamp into UTC/GMT time zone.
Question:
How can I convert a date returned in the Query (E3TimeStamp) into UTC/GMT time zone?
Solution:
To do so, you can use SQL’s DATEADD function.
Example:
SELECT DATEADD(minute, <%TimeZone%>, Alarms.E3TimeStamp) AS UTCTime, Alarms.Area, Alarms.Message
FROM Alarms
ORDER BY Alarms.E3TimeStamp ASC
Thus, the time zone can be set up (in minutes) via SQL’s TimeZone variable.
Print Friendly, PDF & Email
Leave a Reply
