Question:
How much bandwidth is consumed by a Viewer on a TCP/IP network?
Solution:
There isn’t a single answer to this question, since the value will depend on the application. Therefore, we suggest creating tests with the application for checking this information.
NOTES:
- If the application has too many bitmaps, gifs and wmfs files, the execution becomes slower.
- When you run the application for the first time, it will be slower, because the data is being loaded in the E3Cache folder.
- You can use programs that filter how much bandwidth can be consumed by a certain IP.
