KB-31158: WebService’s SetParams() method’s arguments.
Question:
Which arguments must be passed via SetParams() method?
Solution:
SetParams() method’s parameter is called ArrayOfAnyType, that is, it is an array of any type. In Elipse E3, this parameter will be received in an I/O block.
Print Friendly, PDF & Email
Leave a Reply
