Question:
Can a recipe file (*.rcp) be exported to Excel?
Solution:
Currently, there is no automatic way to do so.
A possible solution is to create an auxiliary historic and “run” the recipe(s) copying their records to the historic, which must be linked to a formated report. Then, use PrintToFile function to export the data. Notice, however, that this script needs to load all recipes, so this is not advisable for I/O tags.
NOTE: Attached to this article is a demo application that reproduces the solution above. This application was developed with Elipse SCADA 2.29 build 92.
