KB-31111: Creating new historic files with current date on their names.
Question:
How can I rename historic files (*.dat) according to the number of records and setting the current date on their names?
Solution:
You can do this by using a crono tag with a 60-second preset. It checks every minute if there is more than a number X of records, and then creates another .DAT file. The tag’s script will look like this:
Dim RecCount, path, Date
RecCount = Hist1.GetRecCount()
IF RecCount > 20
   Date = Format(“dd-mm-yyyy_hh-mm-ss”, currentTime)
   path = “file_” + Date + “.dat”
   Browser1.Query.filename = “”
Hist1.Close()
   Hist1.filename = path
   Hist1.Open()
   name = Hist1.filename
   Browser1.Query.filename = name
ENDIF
NOTE: Attached to this article is a sample application developed with Elipse SCADA 2.29 build 92.
KB31111_en
Print Friendly, PDF & Email
Leave a Reply
