KB-31087: E3Viewer’s version to access a remote E3Server.
Question:
Which E3Viewer‘s version must be used to access an E3Server v. 3.0 b. 453, for example?
Solution:
Any version equal to or higher than the version being used with the E3Viewer will be compatible with the E3Server. However, we recommend that you use the same version on both the E3Server and the E3Viewer.
Print Friendly, PDF & Email
Leave a Reply
