Question:
How can I restrict an authorized user from viewing and editing data according to the computer they are using?
Solution:
To do so, you can create a script in the Viewer‘s OnStartRunning or OnLogin event. For example:
Sub Viewer_OnLogin()
PCName = GetComputerName()
If PCName = "Processo1" Then
Item("NumMaq").Value = 1
ElseIf PCName = "Processo2" Then
Item("NumMaq").Value = 2
End IF
In this example, NumMaq is a Viewer’s internal tag.
After that, link the screen objects’ Enabled property to NumMaq tag’s Value property according to the computer accessing the application. You can group objects as needed and create a table connection for them according to the value passed to NumMaq tag.
