Question:
Can I connect E3 to a Pervasive Database via ODBC?
Solution:
Yes, you can, but there are technical problems. You must know the connection string, and you cannot use E3’s Database and E3Query functions.
Therefore, we recommend analyzing the case to be really sure about the necessity of this configuration. Sometimes, it is easier to use an SQL Server, Oracle, or Access database, and create a StoredProcedure routine to export data to the Database that does not have native access to E3.
