Question:
If an application starts with an Access database and in the middle of the process it migrates to SQL/Oracle, will the previous data be sent to the new database?
Solution:
No; only data recorded after the migration will be inserted by E3 in the new database. The previous data can be exported from Access to SQL/Oracle via tools in this database or via a Stored Procedure.
