Question:
How can I deactivate a Driver that is not being used?
Solution:
To do so, follow these procedures:
- Open the Organizer
- Expand Drivers sub item
- Select the Driver to be deactivated
- Click Advanced button
- Uncheck Start driver at application startup option
- Press OK
When the application is executed, the driver will not be loaded, and no communication will happen with it, unless this option is once again checked and the application is restarted.
