KB-30938: Exporting I/O tags.
Question:
Can I export a driver’s I/O tags to a list in Excel format?
Solution:
Yes, you can. To do so, you must right-click the driver object and choose the option Export…. Then, select the folder and name for the file with .CSV extension.
Print Friendly, PDF & Email
Leave a Reply
