KB-30898: Proportionally increasing the size of a screen object.
Question:
How can I proportionally increase the size of a screen object (via E3Studio)?
Solution:
To do so, you must hold the Shift key, click the object’s diagonal corner and drag it to the desired size.
Print Friendly, PDF & Email
Leave a Reply
