Question:
Can I change a SetPoint into a Display, and vice versa?
Solution:
Text, Display, and SetPoint are all the same object, named DrawString. The initial settings of some of their properties is the only difference between them.
To change a SetPoint into a Display (and vice versa), you must edit IsSetPoint property.
