Question:
Can Prodave’s communication baud rate be increased?
Solution:
According to the driver’s documentation, you can increase its baud rate via Siemens’ software.
As for Elipse’s driver, you do not have to anything, because it will communicate with the board’s .dll, that is, once the baud rate is increased, the driver will update its communication.
