Question:
Via E3WebViewer, can I open a different screen from the one open in the computer running the E3Server?
Solution:
Yes. The E3WebViewer works as a Viewer Control, that is, more than one Viewer can be opened (via web) for the application in the remote computer. This means that the browsing and login in the open Viewer are completely independent from the ones in the E3Server.
NOTE: there is no need for an open Viewer in the machine running the E3Server to make sure the remote E3WebViewer is working; these processes are completely independent from each other.
