Question:
How can I configure the E3Alarm object to be opened when an alarm is activated?
Solution:
To do so, in the Viewer object, you must create a new event with the following expression:
AlarmServer1.ActiveAlarms <> 0
Then, in this event’s script, you must set up the Open Screen command pointing to the screen with the E3Alarm. This will cause this screen to be executed whenever an alarm is activated, according to this event’s settings (when its condition is True and every 1000ms).
