Question:
How can I limit the number of Viewers per computer to no more than one?
Solution:
To do so, you can create a Viewers Group for each computer, and set the Limit simultaneous license use option as one. This can be done via Viewers Group tab in the domain settings, as seen below.
NOTE: you must register every new computer in the Viewers group; otherwise, its IP will not be displayed on the connections list.
