KB-30656: Reading Modbus 40100 variable.
Question:
How can I configure an I/O Tag to read a Modbus 40100 address?
Solution:
To do so, after you have configured the communication physical layer, follow these procedures in the supervisory:
  1. On driver’s Modbus tab, add a function that uses the following Modbus functions: 03 for reading and 16 for writing.
  2. On driver’s Modbus tab, enable the option Data Addressed from 0 (Modbus addressing on devices by Schneider usually start from 0).
  3. In the application, insert an I/O tag and set it as follows: N1 = 1 (PLC address), N2 = 1 (function created on step 1); N3 = 0; N4 = 100 (corresponding to 40100 address).
Print Friendly, PDF & Email
Leave a Reply
