KB-30556: Script error with Overflow message.
Question:
On Windows 2003 Server SP2, when executing scripts that work with Double data, a script error occurs with an Overflow message. How can I fix the problem?
Solution:
To do so, install Microsoft’s HotFix according to this link: http://support.microsoft.com/kb/955536/en-us.
Print Friendly, PDF & Email
Leave a Reply
