Question:
Can I have more than one query per report?
Solution:
No; reports in E3 can only have one query. If you need to use different SQL commands, just pass them to the report’s query via scripts:
Example 1 – “Button 1” (print values from tag demo1):
Set Report = Application.LoadReport(“[Report1]”)
Set Query = Report.Item(“Query1”)
Query.SQL = “SELECT Historic.E3TimeStamp,Historic.TagDemo1 FROM Historic ORDER BY Historic.E3TimeStamp ASC”
Query.Table = “Historic”
Query.OrderBy = “Historic.E3TimeStamp ASC”
Query.Fields = “Historic.E3TimeStamp,Historic.TagDemo1”
Query.DataSource = “Database1”
Query.Execute()
Report.Export “PDF”,”testeelipse1.pdf”
Example 2 – “Button 2” (print values from tag demo2):
Query.SQL = “SELECT Historic.E3TimeStamp,Historic.TagDemo2 FROM Historic ORDER BY Historic.E3TimeStamp ASC”
Query.Fields = “Historic.E3TimeStamp,Historic.TagDemo2”
Query.Execute()
Report.Export “PDF”,”testeelipse2.pdf”
NOTE: Attached is a sample application developed with E3 version 3.1 Build 270.
