Question:
How can I generate an E3Chart‘s report?
Solution:
In case of historic pens, you must insert an E3Chart in the report’s PageHeader section and use CopyConfig method in OnBeforePrint event to copy the settings of the E3Chart on the screen. In case the screen is open on a modal window, the name of the frame being used is Splitter1.
Example:
set chartSceen = Application.GetFrame(“Splitter1”).Screen.Item(“E3Chart1”)
NOTE: The attached demo application was developed with Elipse E3 v. 3.1 b. 270.
