Question:
When I execute a script with HistoricName.Analysis() as an administrator logged into Windows XP, it works properly. However, when another type pf user logs in, the options on the analysis window remain disabled. How can I fix the problem?
Solution:
To do so, you must configure Windows XP to allow all users to access the folder where the Historics are being stored. If the user logged into Windows XP does not have access permission to the folder where the Historics are being stored, the options on the Analysis window will remain disabled.
