KB-30415: Increasing the size of the window opened by the ShowDatePicker() method. 25 de March de 2019Elipse Software2 Comentários on KB-30415: Increasing the size of the window opened by the ShowDatePicker() method. Question: Can I increase the size of the window opened by a script using the ShowDatePicker() method? Solution: No, you cannot. The size of this window only increases if the screen’s resolution changes. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
Then what is the solution of the same. Up Down arrow for time is too small to operate.
