KB-30359: Exporting a report to PDF.
Question:
How can I export a report to PDF format?
Solution:
To do so, you must first download a PDF printer (PDFCreator, for example) and set it as Windows’s default printer.
Then, in Elipse SCADA, add a script (in a button, for example) using the report’s Print() function. Thus, this button creates a PDF file with the report’s historical data whenever it’s pressed.
Print Friendly, PDF & Email
Leave a Reply
