KB-30265: Changing the default font of a Text object on SCADA.
Question:
Is it possible to change the default font of a Text object on SCADA?
Solution:
No, it is not, because this is hard-coded on SCADA. So, you must change it manually when necessary.
Print Friendly, PDF & Email
Leave a Reply
