Question:
Why is a Query’s filter using the LIKE clause not working when typing just a part of the word to be filtered? For example, when typing “tag”, only the word “tag” is displayed, but tag001, tag002, etc., are not displayed.
Solution:
To check every message which has a certain word, you must place it between two percent signs ( % ). For example, on a Query where the variable’s name is var, and Text1 is the Display where the word to be filtered was inserted, you must write the following:
filtervar = “%” & Screen.Item(“Text1”).Value & “%”
set query = Screen.Item(“E3Browser1”).Item(“Query1”)
query.SetVariableValue “var”, filtervar
Below, you can see the available filters for the Query:
- LIKE ‘A%’ All messages starting by A
- LIKE ‘%A%’ All messages containing A
- LIKE ‘_NG’ All messages starting with any character followed by NG
- LIKE ‘[AF]%’ All messages starting by A or F
- LIKE ‘[A-F]%’ All messages starting by any letter between A and F
- LIKE ‘[A^B]%’ All messages starting by A where the second character is not B
