Question:
E3 frequently hangs, so I have to either restart it or restart the computer. On the E3 log, errors as the following ones are registered:
- Variant Marshalling Failed (8001010E) VT=00000009
- Error E00500: Out of Memory!
How can I fix this?
Solution:
This problem happens when you attribute an object to a retentive Internal Tag when HotStandBy mode is on.
To fix this, you must update your version of E3 to at least v. 3.2 build 260.
NOTE: All versions of E3 are available for download at Elipse’s website.
