KB-30035: Printing an RMChart object.
Question:
On a screen with different types of objects, can I print only the RMChart and not the others?
Solution:
Yes. To do so, you will either use ActiveX’s Draw2File() function to generate a figure (for example, a JPG), or Draw2Printer() function to generate a PDF file.  For the latter case, however, you will need to have a PDF generator already installed in your machine set as default.
Example:
Set Chart = Screen.Item(“RMChartX1”)
Chart.Draw2Printer()
Functions structure:
Draw2Printer([nPrinterDC], [nLeft], [nTop], [nWidth], [nHeight], [nFileType]))
Draw2File(sFileName, [nWidth], [nHeight]), [nJPGQuality])
For further information or parameters description, please refer to RMChart’s Guide.
Print Friendly, PDF & Email
Leave a Reply
