Question:
How can I set up the number of hardkey detection retries in Elipse SCADA?
Solution:
To do so, follow these procedures:
- Access File menu.
- Click Options.
- In Protection Mechanism, edit Detection Retries option with the desired value:
NOTE: If you don’t have a Setup Module license, you can alternatively set it up via command line:
“C:\Program Files (x86)\Elipse SCADA\Elipse32.exe” -setup
This option forces Elipse SCADA to run the Setup program.
