Question:
Why is the following message being displayed when I try to insert an E3Alarm via E3Studio into screen: “Could not create object. Error code 8007007F“? And why is the Properties window from my E3Alarm is blank when I open it? How can I fix it?
Solution:
To do so, you can close all applications in Elipse E3 (including E3Admin, if v3.0 or higher), and then execute Register.bat file, which is in Bin folder at E3’s installation directory (…\ElipseE3\Bin) . After that, try inserting the E3Alarm into screen again.
