Question:
How can I create a table link in runtime via scripts?
Solution:
To do so, you must first use CreateLink method to create the link, and pass parameter “4” to indicate a table connection. Then, you must use InsertRow method to add rows, values and limits to the table.
Example:
set obj = Screen.Item("Rectangle1")
set bind = obj.Links.CreateLink("ForegroundColor", "Data1.InternalTag1.Value", 4)
bind.InsertRow()
bind.Item(1).Value = RGB(255,0,0)
bind.Item(1).Min = 0
bind.Item(1).Max = 10
bind.InsertRow()
bind.Item(2).Value = RGB(0,255,0)
bind.Item(2).Min = 11
bind.Item(2).Max = 20
bind.InsertRow()
bind.Item(3).Value = RGB(0,0,255)
bind.Item(3).Min = 21
bind.Item(3).Max = 30
Obs.: Attached is a sample application developed with E3 version 3.1 Build 270.
