Question:
Can I open a screen by clicking in a graphic object in another screen?
Solution:
Yes. To do so, you can use an Open Screen pick (as seen below). This pick is on Scripts tab, alongside the other picks used in scripts.
To set up this pick, select the desired graphic object, go to Scripts tab, choose Click event, then select the Open Screen pick and set up its fields as needed.
