KB-29045: E3Alarm’s Operator field remains blank when the alarm is active.
Question:
Why does Operator field in E3Alarm remain blank when an alarm is active, even if there is a user logged to the system?
Solution:
Only when the alarm is acknowledged is Operator field filled. This is because this field indicated the name of the operator responsible for acknowledging the alarm.
Print Friendly, PDF & Email
Leave a Reply
