KB-28904: Problems when history files are too big.
Question:
Why is data recorded on a Historic not being viewed when the *.dat file is too big?
Solution:
This happens because Elipse SCADA can’t open files that are too big. So, to perform Queries, you must configure a by-date filter in the HAnalysis‘ Query.
Print Friendly, PDF & Email
Leave a Reply
