Question:
How can I enable Elipse E3‘s virtual keyboard?
Solution:
At development time, you can do this via E3Studio: access the Viewer’s properties on Viewer tab, and then enable the KeyPad options as needed.
At run time, you can edit the Viewer‘s ShowKeyPadOnEdit property: True to enable it, False to disable it.
