KB-28868: Setting up the Viewer to work with four monitors.
Question:
How can I set the Viewer’s resolution to be used with four monitors in 2×2 format, each monitor with 2560 x 1600?
Solution:
To do so, you must sum the Pixels’ value in X and Y. In this example: 2560 + 2560 = 5120 in X and 1600 + 1600 = 3200 in Y .
Having done that, open the Viewer‘s properties in E3Studio. Select the Start windowed option on the Settings tabs, and configure the Width field as 5120 and the Height field as 3200.
Print Friendly, PDF & Email
Leave a Reply
