KB-28860: Setting up a link between an XControl and an XObject, via scripts.
Question:
How can I set up the property linking an XControl to an XObject, via scripts?
Solution:
This must be done with an attribution, via a string containing the path to the XObject.
Example:Item(“MyXControl1”).Source = “Data.MyXObject1”
Print Friendly, PDF & Email
Leave a Reply
