KB-28761: Recording alarms occurrences.
Question:
When an alarm becomes active, inactive, or is acknowledged, are these occurrences recorded on the same register?
Solution:
For each alarm occurrence (when the alarm becomes active, inactive or is acknowledged), an individual register is recorded in the Alarm History. The E3Alarm object only displays whether an alarm is active or has still not been acknowledged.
Print Friendly, PDF & Email
Leave a Reply
