Question:
How can I uninstall an ActiveX that has been used in E3?
Solution:
To do so, follow these steps:
- Open the Register Editor. To do so, got to Windows’ Start menu, access Run, type “regedit”, and press [Enter].
- On the RE’s window, search for ClassManager folder at: HKEY_LOCAL_MACHINE\SOFTWARE\Elipse Software\ClassManager.
- Inside this folder are all ActiveX added to E3. Just select the object and then delete it.
