Question:
How can I insert Units and Values into a Formula via E3Studio? When I click the + button, no dialog box pops up for inserting unit name or value.
Solution:
This issue can happen when the database is not set up in the application. To fix this, you will need to set it up properly; then right-click the Formula, select the option Configure Database, and insert both the database server and the name of the table created for this purpose.
