KB-28637: Displaying only messages of unacknowledged active alarms.
Question:
Can I display only messages of unacknowledged active alarms in E3Alarm?
Solution:
E3Alarm has a property called CustomFilter, responsible for informing an expression-like customized filter for alarms.
To display only unacknowledged active alarm messages, you can use the following expression in the CustomFilter property:
Print Friendly, PDF & Email
Leave a Reply
