Question:
How can I set up the alarm’s Message column’s width and name?
Solution:
Via E3Studio, go to E3Alarm’s properties window, and on Columns tab select the name of the column you wish to configure: this will enable its properties button. There, you will be able to set its width and name, among other properties.
